how to send AVP_KEYS?
adys
in MAX by AMX
My AVP remote is damaged before I learned it...
I want to use the IR CODES that in the manual.
http://www.amx.com//techdocs/MAX-AVP.InstructionManual.pdf
From what I undestand, I need to send this command via AVP_KEYS?
Can anyone exaplain how to start with it?
I didn't find nothing on the manual and in the forum...
The last UI module support only part of the commands I need ( table 4 at the module document), and in the manual I have text commands...
Ady.
Ady.
When talking about the AVP_KEYS= command, I assume that you talk about the MAX4Plus NetLinx module.
The command syntax isSEND_COMMAND <Virtual Device>,'AVP_KEYS=<zone>:<values>' SEND_COMMAND vdvMAX,'AVP_KEYS=1:29' // To zone 1, PLAY key SEND_COMMAND vdvMAX,'AVP_KEYS=1:2|3' // With the pipe symbol you can send several keys in one single command Here:Zone 1, "1" and "2abc" keys
The DUET MAX module has some more key numbers (where numbers 1..49 are the same arrangement), and handling and syntax are different.
