New MVP firmware? Wireless?
Hey guys,
The current firmware on my MVP7500 doesn't seem to support WPA, so I'd like to upgrade. But I think I remember hearing something about the newer firmware being incompatible with older Masters - is this the case? I have a NXC-ME and would be really ticked if the panel wouldn't work with it anymore.
Dan
Dan
Make sure your panel has an 802.11G wireless card. The older 802.11B cards do not support WPA.
1) open the MVP and check the card. If it has no external antenna, it is 802.11b only
2) upgrade the MVP to the latest firmware. Now in Wireless Settings, it will show you if the Wifi card supports WPA encryption.
The g card can be upgraded with the NXA-WC80211G/CF part:
The newer MVP firmware versions will has some diagnostic tools in Protected Setup->Tools. These diagnostic tools should only be used if the master has firmware 3.21 and up.
Several of our clients have been using the 802.11b since install and it's worked fine for them, until one day out of the blue things got spotty and major problems ensued. After upgrading to the 802.11g card, it was all fixed.
It will probably cost you to upgrade, but it's well worth it and will be a drop in the bucket compared to time spent troubleshooting wireless issues. Note that it's not an end-all fix for some problems, but it sure helps.
Good comment, Dave.
How do I know? I "bricked" an old 8400 following the advise of Tech Support. Missed the middle step that I was not advised of. Called back, and Pete said: You can't do that!
He air freighted me a new CF at no charge......
For the firmware update process:
1) check your current firmware version in the MVP. In setup, check panel information.
2) If it is below 2.63, download the following fw from amx.com: http://www.amx.com/techcenter/downloadConfirm.asp?fn=/assets/firmwareFiles/archive/NX_CVXX_MVPXX00_v2_62_1.kit
Download it to panel, and at the end it will reboot several times.
3) download the regular 2.83.9.
!!! Install the new G card only AFTER the update process !!!
4) After installing the G card and it's completely up to date, download the firmware again.
I was told this is a good habit to get into. Not entirely sure of the benefits, but I've been doing it whenever I add a new G card.
Good point I forgot to tell, thanks.
The G card may also updated from the firmware file of the MVP. So after installing it, it's a good choice to load the firmware again.
Thanks! I'll check it out. Possible that it may already have the G card?
I have all kinds of masters out there with all kinds of TP firmware. It all seems to work just fine.
For a completely different problem I had to set up a NXI-ME (v2.31) with 2 MVP-8400 (v2.83.9) - and it works without any problem. You just should not use the "Connection Utility" from Protected Setup -> Tools. The connection utility will track datagrams sent from and to the master, and if the master's firmware will not support this (like the v2), the master in worst case can lock up.
But again - normal operation should not be affected. Here on my desk the setup is working absolutely fine for days now.
