Channel Codes for TPD 3 - Web Panel
Hi Guys,
Is it possible to have more than 255 channel codes for a G3 TP? Any tips on how to do it?
Thanks guys.
Regards,
Andry
  • Stephen BoltonStephen Bolton Junior Member
    You can set up the panel to be more than one device - up to 4 actually.
    Open your panel, then change the number of devices under panel properties.
    HTH
  • andryalenandryalen Junior Member
    Stephen
    Hi Stephen,
    I thought it would work but it looks like the TPD3 doesn't support it. Thanks anyway.
    By the way I also got this issue, I have a LG Flatron L1730SF that we are planning to use with TPI PRO 2, the touch function doesn't works. We suspect that the TPI doesn't has driver for it. Is is possible to add driver to the TPI PRO?
    Thanks in advance.
    Regards,
    Andry
