Is it possible to....
Rod N
Rod N Junior Member
Can anyone tell me if its possible to lock-out/disable the program port of a master?
  • Jimweir192
    Jimweir192 Junior Member
    You can apply security settings to the programming port via the Master's Security Options.
    Full details are in the Netlinx NIxxxx Manual under security, be very careful though!!!
  • Marc Scheibein
    Marc Scheibein Junior Member
    You can secure the Programming port by the security setup webpages of the master (see attached screenshot). With this setting, only RS232 Terminal is blocked.
    The RS232 terminal contains a secusity setup menu, from which you can turn off and modify the security settings. So personally I would let open the Programming port, because it is the last chance to reset the security settings if you lost your admin account data.
  • Spire_Jeff
    Speaking from experience, BE VERY CAREFUL locking out this port. If you have any problems here, you will have to send the unit in to be wiped clean before you can access it again. If you are looking at this from a security stand point, you could simply not upload the source files which would prevent someone from extracting your code. If, on the other hand, you are worried about someone monitoring communications, I would say you have bigger security problems if they can get access to the programming port.
  • Rod N
    Rod N Junior Member
    Next possibility....
    Thanks all for your replies... its oviously possible... but!
    which leads to the next question....
    Is it possible via code?
