Xantech MRAUDIO8X8 PSA
gusgizmogusgizmo Junior Member
If you can't receive data from the controller, but you can send data, try using a three wire interface. In the cable that was included with the controller, I cut all but red, blue, black, and the ground/shield, after which comm worked.
Thanks guys, this forum helps me out alot, I figured someone else might run into this eventually and will find this in search. I don't suppose there is an AMX wiki out there?
