Need help to control Clearone RAV 900
Hi,
I want to control the clear one RAV 900 from Axcent3 via serial commands. The serial command for the Dial 0 as it's mentioned in the datasheet is like that # 90 DIAL 1 0 with carriage return.
Could anyone please advice me, if the following code works?
send_string dvVC,"'#90 DIAL 1 0',$0D"
kannan
kannan
send_string Dev, "'#20 DIAL 1 0 ', 13";
Make sure your unit is set to ID# 0 as in the #90 ~ #9 ->0 is the unit id
