EPSON DUET MODULE IP CONNECTION
Hy, i'm a new user,
i use the "due module interface for epson vp" with one projector and it's all ok,
can you help me for use more projectors. what must modify in the code ?
thanks.
  • Jimweir192
    Jimweir192 Junior Member
    If you want to control multiple Epson Projectors using the duet module, you just need to declare multiple instances of the module with different names
    DEFINE_MODULE 'Epson_Duet_Module_Name' Unique_Name1()
    DEFINE_MODULE 'Epson_Duet_Module_Name' Unique_Name2()
    DEFINE_MODULE 'Epson_Duet_Module_Name' Unique_Name3()
    I don't know the module directly, but obviously you'll need to pass each instance the correct IP address and any other unique parameters
    HTH
