Memory issues
Hi all
I am having strange problem with my TPs (8400)
Animations are very slow, even the local animation, the system is very very slow.
On my wire TP ( NXT12V) the system is running like it should, very very fast.
Its the same TP file only converted to the NXT version , and it uses the same controllers to get the data.
I connected with telnet to see memory state - in the 8400 I have "largest block" around 3 megs.
In the NXT I have 130 megs.
I have few questions:
1.I want to try and add some memory to the 8400, is the only way to do that is by adding a bigger flash card?
2.Any way to upgrade the ram itself?
3.If not, the flash card upgrade can help me? currently I have 64 megs only...
4.And if I buy a flahs card can I do the upgrade my self - I read all about it here - and didn't find if there is a way to do it...
http://www.amxforums.com/showthread.php?t=382&page=2&highlight=compact+flash
Ady
Ady
It is probably far better to purchase one from AMX if your dealing with a client. But if it's your own, then that is a whole other story!
Ryan
I think that one of the problems is that we are using only PGN-24 with transparency in our project.
we have 1430 images in our file.
Yesterday I made a test and changed all the the images to PNG-8 128 colors
I made export to all , changed them with photoshop script, and import them back
I don't see even one image from some reason?
BUT!
The TP is runing like hell, everything is working so so fast...
I will continue to work this direction and update.
What I really wanted to know if I can upgrade RAM in the 8400 ( from what I read - I can't) and if I upgrade the CF it will help the performance.
thanks
Ady.
I change all the images to PNG-8 and the performance stayed the same.
I removed all animation buttons ( multi state buttons) and made some of the multi states buttons to be general buttons - guess what???
The TP works fast like never before.
Any idea what cause this?
update 3 :
I am very very happy today
I moved all the speaker animations from 64 states to 4 states ( we have lots of them, about 200) and everything is working like magic!
That is very important to know, I never thought that animations can cause the TP not to function, even when not in the page of the animations...
I did it with lots of repeating states to save network transition, but that was like shooting my leg...
I thinks that solve our problem, I never saw the TP working so fast (thouch wood)
P.s
I want to use the auto repeate animation flag, so I will have to turn on the animation only once from the code, and then it will run from the panel alone, someone ever used that?
Thanks.
As for the auto repeat, I have used it with success. It is as straight forward as it seems.
Yes, that could have save me a lot of time.
After all , I did what the TPDesign let me do, so I expected it to work as it should...
My advice, don't do animation with more than 10 states.
About the auto repeat - I need to turn on and off the states (state 4 is off) and to run the animation from state 1 to 3 all the time after I trun it on.
Is it possible to do that?
