Touch Panel Interface
marshoot
We have a New ELO Touch panel interface. Our control system is an AXB-TPI. We were hoping we could just plug it in and it would work, but no such luck. Could someoen tell us what drivers we would need to upload to the AXB-TPI. The touchpanel is an ET1939L from Touch system.
Configuring the touch protocol, either by SEND_COMMAND thru the master, or by terminal directly on the TPI:
The TPI just supports IntelliTouch and Accutouch protocol. From the Tyco homepage, the 1939 screen can be ordered with much more touch types. I don't know if their protocols are identical to IntelliTouch or AccuTouch."'MOUSE <touch_type>'"
Turn On serial mouse or other touch devices by setting the serial touch
interface type. When changing the serial touch device, you must connect
the hardware before setting the device type. This command soes NOT allow
you to "turn mouse off". The <touch_type> is the touch mode from below.
Syntax:
SEND_COMMAND <DEV>,"'MOUSE <touch_type>'"
Variables:
Serial touch types <touch_types>:
00: Touch OFF touch interface (Microsoft? serial mouse)
01: Microsoft? serial mouse (PC Presenter)
02: Second Microsoft? serial mouse (MX-MM MobileMouse)
10: Dynapro? mouse
11: MicroTouch?
12: Elo IntelliTouch? touch monitor (G3 touch panels)
13: Elo AccuTouch? touch monitor and VTM-D15/A MultiMedia
Touch Panel
15: EZ Screen? touch monitor
8000: Touch Output to Serial Port (Elo IntelliTouch)
FF: External touch driver
Example:
SEND_COMMAND Panel,"'MOUSE 11'"
Sets the touch interface to MicroTouch.
http://www.elotouch.com/products/LCDs/1939L/default.asp -
Interface
Thanks that worked. the drivers were already in the TPI we just need to resign and calabrate.
