MVP 7500
kenlok16
Hi all,
After loading my design to the panel, the edge of the buttons looks 'extent' along its vertical size, may be I should attached a pic, anyone has this issue before? is it a known issue or any solution such as recommanded color tone?
Thanks.
Thanks.
My 7500 has the same deal (if I understand what your saying).
Basically if I have a darker background and a lighter button or line, it continues along to the edge of the screen kind but not the same color tone as the color itself. -
you got it
and it does not appear in other panel such as 8400 -
so do you keep all things in dark? or all in light color? -
This bleeding is a known issue with the passive 7500, you don't see it on the 8400 as it has an Active Matrix TFT display.
There is no real fix - most people avoid these panels whenever possible. The best results will come from sticking with the panel's 12 bit colour palette as it doesn't cope well with trying to estimate additional colours outside it's range. -
Try to keep all the colors in the blue tones, it will help with the over all look.
The 7500 graphics are terrible and should be outlawed. -
Grrr!!
I once stcuked with this panel , but fortunately using Aqua Lens or Digital Dots templates made it a little bit acceptable to the client.
[url=http://www.amx.com/assets/touchPanelResources/Aqua%20Lens[MVP-7500@640x480].tpt]AquaLens[/url]
http://www.amx.com/assets/touchPanelResources/Aqua Lens[/url][MVP-7500@640x480].tpt
[url=http://www.amx.com/assets/touchPanelResources/Digital Dots[MVP-7500@640x480].tpt]DigitalDots[/url]
http://www.amx.com/assets/touchPanelResources/Digital Dots[/url][MVP-7500@640x480].tpt
You may use these templates, or use them as a guide, to avoid its display issue.
Good Luck -
I've heard something along the lines of using a thing black border on the pages helping the "bleed" issue. I can't verify it, I only sold one of the things ever, and subsequently told sales, "never again."
