Panel Offline
Hi i have a level that commands a light dimmer.
When the 8400 wiFi panel go offline ( I hate WiFi!!! ) the level raise up a level 0 event so the dimmer go off.
How can I know if the panel is online or offline?
Thank's a lot!!!
Alex
Thank's a lot!!!
Alex
However, to avoid the level being sent to zero, you will probably be better served by combining your panel with a virtual, and using the virtual instead. Virtuals never go off line unless the master shuts down.
