Daikin IR code
Hi,
I tried to control the Daikin split without success, I just could turn on and off the split ... but coulnd't change the temperature. The IR on AMX database didn't work, so I tried the special mode in IRIS and the commands didn't work too.
Someone help me?
Thanks!
Someone help me?
Thanks!
the solution is change the air con with new one.. hehehe.....
I just wanna say daikin is worst to use if we want integrated system in building
huf* no flag for daikin.... stupid things for daikin..
if we want to control we must buy bugs net module... it's so expensive.......
ck ck ck ck ck http://www.amxforums.com/images/icons/icon13.gif
In you TP create Multistate Bar graph and set the state limit 16 to 32 . and write your code in netlinx
If (lev=16)
Pulse [ac,16]
If (lev=17)
Pulse [ac,17]
If (lev=18)
Pulse [ac,18]
I hope you will be get the idea for this prblem. I have before same problem with Mitsubashi Split AC
