Tandberg 6000
I am having problems with the arrow keys using the AMX to control my tandberg. It doubles every command. If I push the arrow key once it moves twice on the tandberg. If I change the baud rate it goes away for a little bit, but then it comes back.I have a tandberg 6000 connected to a Ni-3000 with a VPT-CP touchpad. I am using the same code on other machines and not having this problem. Any ideas?
Since you mentioned Baudrate i'm guessing the control is via RS 232 if it's IR change the pulse time.
Check on the Tandberg what baud rate is applied. From memory it's under control panel - admin - network - data port. The 6000 has two RS232 ports, one for external control (AMX), second for camera. The settings you should be checking is data port 1.
Hope this helps!
