TIMELINE_KILL question
Is there any reason why I need to check to see if a TIMELINE is ACTIVE before I KILL it? I know it generates an error of invalid ID if it?s not ACTIVE to begin with but I?d like to know if there are any negative repercussions in performing a direct KILL.
Joe
  • AFAIK it's just a runtime error without any effect (I never have seen any)
  • DHawthorne
    DHawthorne Junior Member
    I have always assumed runtime error = bad. You never know when it will have unforseen detrimental effects, including processor bog down while it handles the exeptions. So I always test if the timeline is active first. I also test any timeline I am starting up if outside of the DEFINE_START section. It would be nice, all that said, if the functions tested internally; it seems simple enough to do.
  • Originally posted by DHawthorne
    I absolutely agree :-)
  • Chip Moody
    Chip Moody Junior Member
    I always thought runtime errors were only bad if you weren't expecting them. :)
    Seriously, if you call TIMELINE_KILL and get a "no such timeline" error, that shouldn't be a problem... Right?
    Where's our official AMX guys to answer this one?
    - Chip
  • DHawthorne
    - Chip
    Maybe, maybe not. There is usually added processing to handle this kind of exception, so it is probably more efficient to test first so it doesn't happen. If it only ha[ppens once in a while, or if the rest of your code is pretty simple, it probably doesn't matter. But get a real complex system, and such things can cause timing issues and other problems which are really hard to track down. It's entirly possible that the function actually does just test internally and spit out the message, making my argument moot. But unless I knew for sure, I'd rather it ran clean.
