Home AMX Forum AMXForums Archive Threads AMX Applications and Solutions VisualArchitect
web update?
hi
i can't seem to find the web update software anywhere on the AMX website. I've just installed VA and it says i need to install the web update to get the latest updates but it's almost impossible to find as none of the search results link to it at all
Cyril
    1) type "webupdate" in the search box on AMX.com
    2) the first result is "Download WebUpdate"
    3) click Select Category menu and pick WebUpdate
    4) the first result has a download link for an .exe, run it
    In my opinion this should be a 2 step process and not a 4 step process. If you want to encourage your visitors to download a program to keep their software updated, it should be available from the homepage much more easily.
    mpullin wrote: »
    Hah! You should see how many clicks it takes to change the master communications IP address in Netlinx Studio 2. It takes 9 clicks to change one setting. :|
  • cyril.limcyril.lim Junior Member
    arrrhh.. finally
    well.. AMX has quite a bit to learn from the competition where the webupdate is built into the program so you just enable or disable it.
    since it's required by VA, it should probably be linked from the VA product page.
