DUET Module for DAS-MI0808
Hello everybody.
I'm searching the DUET file for the Distributed Audio Matrix DAS-MI0808. Can somebody give me please a link to the AMX.com Download. Thank you!
Greets from germany
T.Hocke
  • Jurgen Sachs
    Jurgen Sachs Junior Member
    Please go to www.amx.com and log in.
    Goto "Tech center"->"search third party devices" and insert "amx matrix" as manufacturer.
    This will bring you a list with the required module.
    If you have problems accessing the tech center, please call tech support.
    Greetings from Germany
    Juergen Sachs
  • Denis
    Denis Junior Member
    Communication with MI unit
    HI
    I try to install Matrix module but I get big problem. I tried the modules itself without any other files., and noting at all works. On my touch panel, I get only page title and buttons room menu and keypad unlocked. The Room menu isempty too. The small pilot in bottom panel is off.
    I tried the duet module who is downloadable separately always without succes.
    Somebody can help me?
    In the same work, do I to mapp AMX_MatrixAudio_MiSeries_UI with panel device?
    Sorry for this stupid question but I begining to work with modules.
    Always in the same work, when I transfert the files I get that
    Send Failed 0 of 403 NetLinx-192.168.0.130:1319 0:1:0 AMX_MatrixAudio_MiSeries_MAIN.mf C:\DOCUME~1\Denis\LOCALS~1\Temp\DuetTemp8\ Transfer Aborted - Unsupported file type. Thursday, February 26, 2009 11:44:19
    Send Failed 0 of 115175 NetLinx-192.168.0.130:1319 0:1:0 AMX_Matrix_MiSeries_Comm_dr1_0_1.jar C:\DOCUME~1\Denis\LOCALS~1\Temp\DuetTemp8\ Transfer Aborted - Unsupported file type. Thursday, February 26, 2009 11:44:19
    Send Failed 0 of 916064 NetLinx-192.168.0.130:1319 0:1:0 devicesdkrt.jar C:\DOCUME~1\Denis\LOCALS~1\Temp\DuetTemp8\ Transfer Aborted - Unsupported file type. Thursday, February 26, 2009 11:44:19
    Send Complete 120429 of 120429 NetLinx-192.168.0.130:1319 0:1:0 PROG.tkn C:\DOCUME~1\Denis\LOCALS~1\Temp\DuetTemp8\ None Thursday, February 26, 2009 11:44:19
    Send Failed 0 of 535001 NetLinx-192.168.0.130:1319 0:1:0 snapirouter.jar C:\DOCUME~1\Denis\LOCALS~1\Temp\DuetTemp8\ Transfer Aborted - Unsupported file type. Thursday, February 26, 2009 11:44:19
    Send Complete 246 of 246 NetLinx-192.168.0.130:1319 0:1:0 empty.src C:\DOCUME~1\Denis\LOCALS~1\Temp\ None Thursday, February 26, 2009 11:44:19
    The failed transfert are normal?
  • Joe Hebert
    Joe Hebert Junior Member
    Denis wrote: »
    No that's not normal. Do you have DUET firmware loaded in the Netlinx Master?
  • Denis
    Denis Junior Member
    Yeah! but....
    I updated the firmare with the last kit on AMx web site, and all tranferts are good Yeah!
    But I'm always unable to do work module for Matrix audio......
