ZigBee Latency
Dear all,
During my first R4/ZigbeeGareway installation I realized that there was a big latency in the zigbee network. In the R4 setup page, we saw a latency value of 65535 which I think this is the largest one and no button pushes could be sent to the NetLinx controller.
To tell the truth there is a WiFi access point (there may be two) in this room which has been set up by our customer network administrator.
I'm afraid that it has something to do with the interference between the two networks.
How can we check that and how can we solve this problem?
Any help will be very useful.
Thanks in advance,
George
Thanks in advance,
George
I've seen that latency before but I never figured out what caused it, possibly to much feedback over loading the Gateway causing it to drop offline. Are you using the feedback module?
George
Because modifying all your code to accomodate feedback limitations and causing the Gateway to fall offline you should really get and install the R4 feed back module which buffers or queues all channel feedback and strings being sent to the R4 and controls their timing based on a number of factors such as number of hops to the gateway, number of R4 devices etc.
I think on average you're limited to around 20 messages to the R4's per second. I'm not sure if it makes much difference if it channel, string or level feedback although more than 20 strings per second will most definitely kill it.
It sounds like you are using the old firmware. Update to the new firmware and your latency may disappear. You can also try using the AMX R4 Comm module that will parse feedback to the R4s.
Paul
George
Just as a note, I was told never ever to use Channel 25 for the Zigbee remotes by AMX, as they use that channel for some sort of reflection. In fact the option to choose channel 25 is removed in the current firmware.
Here's a link that I posted when they first started shipping the R4s that discusses zigbee and wifi interfernece that I've been using as a reference.
http://www.xbow.com/Products/Product_pdf_files/Wireless_pdf/ZigBeeandWiFiInterference.pdf
