Need help with i!-EquipmentMonitor
rorrrorr Junior Member
Trying to setup an NI-4100 so that I can send an email to start a room. Basicly, I have the master setup and checking an email account correctly. But im having a hard time figurning out how to setup a buffer that would parse the email, and then setting up a way to look for a string and then executing a call or function.
Im new at this, im hoping someone out there has done this, or can help out.
ANY HELP IS MUCH APPRECIATED!
-RCO
    -RCO
    Equipment Monitor is mostly used to notify a help desk when there is a problem in the room. If you want to control functionality in a room, I would suggest RMS/Meeting Manager. There is actually a free vesion of meetingmanager for facilities with 5 rooms are less. Not sure what you are trying to do, but MeetingManager is a better tool.
  • rorrrorr Junior Member
    Thanks for the help
    Thanks Jeff, I was just trying to over complicate things. I currently use I!-Email to send emails for help requests, i was just going to see if i could use the email function of I!email to send emails directly to controlers.
    Thanks for all your posts, im sure you have helped 100s of people.
    -RCO
  • REBUILD_EVENTREBUILD_EVENT Junior Member
    Does anyone know if there is a possibility to attach multiple files to an email with Equipment Monitor? By now, sSmtpQueue[].cFile[] seems to be used for a single file...
