Function pointers
One thing that Netlinx is missing that I miss from C is function pointers. Has anyone tried to implement something similar? I could use it in this job where I have 100 functions that will activate any one of 10 devices in 10 zones. So for device 1 which is a DVD I have 10 functions, one for each of the 10 zones. ie: kitchenDVD, mBedDVD, livingDVD etc.
However, if I want to start the DVD in all 10 rooms at once, I have to write a switch that takes the zone and then calls the appropriate function for each zone.
Its alot of code to do something pretty basic.
What I would do in C, is have an array of 100 function pointers so that for each input/output combination I just call the function that the pointer in the array points to.
I can't figure out a way to do this in Netlinx because there are no pointers but I am wondering if someone has implemented something similar with virtuals, events etc?
I won't know at compile time what device/zones the user will choose, so I need a way at runtime to change the function that is called depending on the device and zone. I was hoping that there would be a better way than hard code all the function calls.
Paul
if (device == DVD)
switch(output)
case mBed:
mBedDVD()
case kitchen:
kitchenDVD()
if (device == DVR)
switch(output)
case mBed:
mBedDVR()
case kitchen:
kitchenDVR()
for (int i = 1;i <= 10;i++)
call functionptrArray[i] // approx in Netlinx
Paul
DEFINE_FUNCTION TURN_ON(INTEGER zone, INTEGER src){ switch(src){ case 1: // dvd player switch(zone){ case 1: // bedroom? // turn on bedroom DVD break; } break; case 2: // etc. break; } }Now you can create loops to make calls to that function if you wish./* pseudocode */ button_event[dvTP, 100] { for (cnNumZones) { currentZone = currentZone + 1 do_push(dvFamilyTP, 20) } }Right now I have it set up where my button events for devices contain a switch like so:
button_event[dvTP, 20] { push: { switch(currentZone) { case cnMBed: { mBedDVD() } case cnKitchen: { kitchenDVD() } ... ... } } }Is it possible for the timing of the do_push and the increment of the currentZone variable to get screwed up such that the for loop finishes before the do_push gets executed? I assume button_events are executed on an as needed basis so you have no way of knowing exactly when (it terms of where the code is) it starts and finishes.
Paul
send_string u_display[iDisplay].dv_device, iCmd
or
pulse[u_source[iSource].dv_device, iCmd].
Doing it this way can eliminate a lot of switch/cases.
Thanks, I do something similar, but the issue is that I want to call a function not send a string, command or pulse. I am guessing there is no way to do this other than come up with some other scheme. There doesn't seem to be a way to dynamically call different functions at runtime without hard coding it all.
Paul
