4 digit Channels
I just thought I'd post a call I made to sort of emulate the XCH command, but this one works with the new 4 digit channels found on the DISH Satellite network.
Hope this helps someone. Also, feel free to let me know how I can improve my coding.
DEFINE_CALL 'SEND CHAN' (DEV dvIROUT, INTEGER nCHAN, INTEGER nENTER_CHAN) // Same as XCH, but supports 4 digit channel { STACK_VAR INTEGER x1 STACK_VAR INTEGER x2 STACK_VAR INTEGER x3 STACK_VAR INTEGER x4 x4 = nCHAN/1000 + 10 IF(x4-10) SEND_COMMAND dvIROUT,"'SP',x4" x3 = (nCHAN - ((nCHAN/1000)*1000))/100 + 10 IF(x4-10 or x3-10) SEND_COMMAND dvIROUT,"'SP',x3" x2 = (nCHAN - ((nCHAN/100)*100))/10 + 10 IF(x4-10 or x3-10 or x2-10) SEND_COMMAND dvIROUT,"'SP',x2" x1 = (nCHAN - ((nCHAN/10)*10)) + 10 IF(x4-10 or x3-10 or x2-10 or x1-10) SEND_COMMAND dvIROUT,"'SP',x1" IF(nENTER_CHAN) SEND_COMMAND dvIROUT,"'SP',nENTER_CHAN" }
