DPS to CHAR Array?
Greetings,
I am working on a system where various client systems send requests to a server system.
I am trying to find a way to convert the DPS of the sending virtual device from its device definition to a character array to include as text in the command being sent so that the server would know where to send the response back to.
Does anyone know of some embedded function that creates such arrays?
For example:
In the client module:
Where the server module would see:
This Message Came From 33000:1:100
and would be able to send a message back to the client.
Thanks.
For example:
SEND_STRING vdvServer,"'This Message Came From ',<DEV string>"
Thanks.
DEFINE_FUNCTION CHAR[11]fnDEV_TO_STRING(DEV iDEVICE)// { RETURN "itoa(iDEVICE.NUMBER),':',itoa(iDEVICE.PORT),':',itoa(iDEVICE.SYSTEM)" ; } //some where in the code! SEND_STRING vdvServer,"'This Message Came From ',fnDEV_TO_STRING(dvSomeDevice)" ;On the other side you can do the opposite function fnSTRING_TO_DEV if needed.
Thanks dude!
