code for radia lights
Has any one ever used Radia Lighting controlers with a NXI master? The issue that I am running into is that when ever you turn off a Radia device channel number for the off channels (135-140) the actual relay does not turn off untill about 5seconds after you turn on the channel, also if you try and turn off multiple lights(ie relays) one right after the other the channels for off come on but the lights dont go out.This may seem confuseing so i have attached my code to show more detail
PROGRAM_NAME='LIGHTS'
DEFINE_DEVICE
dvRadia = 96:1:0 //RADIA LIGHTING CONTROLER 1
dvPLK_SB1 = 6001:1:0 //PLK-SD LIGHT SWITCHES
dvPLK_SB2 = 6002:1:0 //PLK-SD LIGHT SWITCHES
dvPLK_SB3 = 6003:1:0 //PLK-SD LIGHT SWITCHES
dvPLK_SB4 = 6004:1:0 //PLK-SD LIGHT SWITCHES
dvPLK_SB5 = 6005:1:0 //PLK-SD LIGHT SWITCHES
dvPLK_SB6 = 6006:1:0 //PLK-SD LIGHT SWITCHES
vdvPLK_SB1 = 36001:1:0 //PLK-SD LIGHT SWITCHES
vdvPLK_SB2 = 36002:1:0 //PLK-SD LIGHT SWITCHES
vdvPLK_SB3 = 36003:1:0 //PLK-SD LIGHT SWITCHES
vdvPLK_SB4 = 36004:1:0 //PLK-SD LIGHT SWITCHES
vdvPLK_SB5 = 36005:1:0 //PLK-SD LIGHT SWITCHES
vdvPLK_SB6 = 36006:1:0 //PLK-SD LIGHT SWITCHES
DEFINE_EVENT
BUTTON_EVENT[vdvPLK_SB1,1]//on
push:{on[dvRadia,129]}
BUTTON_EVENT[vdvPLK_SB1,2]//off
push:{on[dvRadia,135]}
BUTTON_EVENT[vdvPLK_SB2,1]
push:{on[dvRadia,130]}
BUTTON_EVENT[vdvPLK_SB2,2]
push:{on[dvRadia,136]}
BUTTON_EVENT[vdvPLK_SB3,1]
push:{on[dvRadia,131]}
BUTTON_EVENT[vdvPLK_SB3,2]
push:{on[dvRadia,137]}
BUTTON_EVENT[vdvPLK_SB4,1]
push:{on[dvRadia,132]}
BUTTON_EVENT[vdvPLK_SB4,2]
push:{on[dvRadia,138]}
BUTTON_EVENT[vdvPLK_SB5,1]
push:{on[dvRadia,133]}
BUTTON_EVENT[vdvPLK_SB5,2]
push:{on[dvRadia,139]}
BUTTON_EVENT[vdvPLK_SB6,1]
push:{on[dvRadia,134]}
BUTTON_EVENT[vdvPLK_SB6,2]
push:{on[dvRadia,140]}
DEFINE_PROGRAM
[dvPLK_SB1,1] = [dvRadia,129]
[dvPLK_SB1,2] = [dvRadia,135]
[dvPLK_SB2,1] = [dvRadia,130]
[dvPLK_SB2,2] = [dvRadia,136]
[dvPLK_SB3,1] = [dvRadia,131]
[dvPLK_SB3,2] = [dvRadia,137]
[dvPLK_SB4,1] = [dvRadia,132]
[dvPLK_SB4,2] = [dvRadia,138]
[dvPLK_SB5,1] = [dvRadia,133]
[dvPLK_SB5,2] = [dvRadia,139]
[dvPLK_SB6,1] = [dvRadia,134]
[dvPLK_SB6,2] = [dvRadia,140]
What happens is if you turn on any on channel for a zone the channel turns on and the lights turn on. If you turn on an off channel the relay takes about 5 seconds to turn the lights off.Any help would be great.I
