Recommendation for an IP-232 box.
I?d like to control 16 plasmas via 232 over an IP box.
I?ve heard there are some out there for $100 or so.
Anyone have good experience with a particular manufacture?
thx.
thx.
What is the difficulty with the Extron boxes? They seem to me to be a touch "feature rich", but they seem to work fine in the simple pass-through mode. We don't run into a need for IP to RS232 interface often so if there's a problem with the Extron boxes I don't know about, I'd like to so we can avoid either the problem or the boxes.
well, you can use them in two ways. You can use passthrough, this way you don't get feedback.
You can also telnet on the RS232 port (port 2001 standard) and you get "full" control over the RS232 port, which means your commands are sent and received transparant (feedback)
The only this is, i've had some problems with keeping the Extron boxes connected. Not sure if it's AMX or Extron related, but checking in a timeline every 10 seconds if an Extron box is connected doesn't cut it for me...
