Help while transfer .irl file
Hello!
I'm a begginer in amx programming and i'm having a problem while transfering the .irl files to the ni controller. The only file that i can't transfer are the .irl files...Can anyone help me?
Thank you very much!
  • yuriyuri Junior Member
  • Jimweir192Jimweir192 Junior Member
    Have you mapped the file to the correct port (right click on IRL in workspace and select device mapping)?
    What error message do you get when trying to transfer?
  • mritzmritz Junior Member
    I have 2 projects where I also had problems with transfering some of the IR-files. When I tried to transfer the files with Netlinx Studio 2, it crashed. The solution was to transfer the files with the IR-Edit program. I think this was a special problem with the IR-files.
  • cristibadcristibad Junior Member
    thanks.
    i solved the problem. it was a mapping thing.
    now i have another problem. how to comunicate with EIB? we have a comm-tech gateway wich should convert rs232 to EIB. i would be gratefull if anyone of you can send me a sample of a code. i found some samples on this forum but they are old, they are for EIB4 and i have 6. i tryed this code for a button but it didin't work.
    botton event
    PUSH
    send_command vdvEIB,"' set = 14/0/2:2'"
    i think it should send the rs232 signal, but it doesn't
    cristibad wrote:
    thanks.
    botton event
    PUSH
    Use SEND_STRING, not SEND_COMMAND. The command version talks to the RS-232 device itself, and is used for configuration and setup. The string version is for passing it out through the serial port.
    It will be great if someone can send me a simple project file containing an examplig of sending some eib code because i really can't do it.
    Thank you very much
    solve that one to :). conecting via telnet helped me alot to see what was going on
