SpeakerCraft MZC Module
Anyone used the Duet module in the inconcert section of the AMX site?
I'd like to use it, but am somewhat baffled by the instructions.
The MZC 88 is the specific product I'm trying to use it with. The MZC 88 has 2 tuners (inputs 1 and 2) and 6 external inputs, and 8 outputs zones.
It appears from the example with the module that you create a virtual device port for each output (or zone) that the device has; 8 in my case. However when you look at the page titled 'Port Mapping', it suggests that only port 1 and 2 of the virtual device accept the tuner commands.
This runs counter to my intrepretation that each virtual device port is to be viewed as an output zone (since the tuners are inputs).
Anyone able to clear up my confusion....
Rich
Rich
