Samsung LNT3242HX & RS232
Hi All...
Does someone have any experience with a Samsung LNT3242HX LCD TV? We have to replace an existing 32" plasma that lost it's RS232 brains in a lighting storm. Since it is 5 years old, we're considering just changing it out versus the $$$ to repair, with no guarantee of other damage elsewhere.
No offence inteneded but trying to deal with consumer level technical support and asking if they have the RS232 protocol for the unit is, ahem, a challenge.
The TV has an RS232 port, and they have some sort of multi display control software that uses said port, so one would expect...
Any input?
Cheers!
  • pauljlozpauljloz Junior Member
    The following is very useful. There are also some extended codes for other models.
    Cadillac P7(HP-S4273, HP-S5073) products for USA can control the basic functions of TV by transmitting
    the command through Serial Port of PC by linking TV to PC. Service terminal which is attached to TV is
    used to link TV to PC.Because this service terminal is the form of Headphone Jack and consists of Tx,
    Rx, GND, pins related to modem among UART line are not used. when control of TV with linking to PC,
    please use Phone Jack ↔ RS232C cable which is the same form of using service.
    2. The operation specification
    1) PC COM Port Setting method
    Select one of COM 1,2,3,4 and link TV to relevant Port. Set COM Port as below.
    Port Choose the number of linked COM Port
    Baud rate 115200
    Data bits 8
    Parity None
    Stop bits 1
    Flow Control None
    2) Transmission Command and operation
    Command Operation
    'P' Toggle Power On/Off
    'N' Power On
    'n' Power Off
    'v'
    Source conversion(TV/Video
    conversion )
    'u' Channel Up
    'd' Channel Down
    '0' ~ '9' Number Key
    'l' (small letter L) Volume Down
    'r' Volume Up
    ※ '!' ~ ')' are Shift + number key
    3. The operation test
    To check if the function is conducted in a correct order, link TV to PC and input the texts above on
    Hyper Terminal and check if the operation is conducted well.
    Command Operation
    '!' convert into AV1
    '@' convert into AV2
    '#' convert into S-Video1
    '$' convert into S-Video2
    '%' convert into Component1
    '^' convert into Component2
    '&' convert into PC
    '*' convert into HDMI1
    '(' convert into HDMI2
    ')' convert into RF broadcast
  • the8thstthe8thst Junior Member
    This may help as well, but it is for a Plasma....
