Fujitsu RS232 malfunction?
mpullin
mpullin Obvious Troll Account, Marked for Deletion
Anyone ever seen activity like this before on a Fujitsu plasma's RS232 port?
  • NMarkRoberts
    NMarkRoberts Junior Member
    Looks like noise to me...
  • Joe Hebert
    Joe Hebert Junior Member
    That would be my guess too although there are an awful lot of nulls. Maybe it's an intermittent cable or maybe the Fuj had a mental breakdown or maybe as Mark said it's just noise.
    I assume you are not using a pre-made cable, correct? If I recall correctly, the Fuj has voltage on the handshake lines. If pins 4 and 6 are getting thru to the NI comm port that can cause problems like this since Netlinx uses those pins for RS-422/485.
  • mpullin
    Thanks a lot for your input guys. What do you mean by noise? Something is messing with the wire in the wall?
  • jazzwyld
    jazzwyld Registered User
    Yep...
    I've had the pleasure to deal w/ Fujitsu's as well. I've noticed the same spooge from time to time. I think you're just seeing a hiccup in the RS-232. Not everyone makes solid RS-232 protocols...such a pity.
  • mpullin
    There are three other Fujitsus in the same system that are working, so I'm thinking it's either this TV itself, a problem with the cable, or an issue with the card on the NI4000 (not likely).
  • NMarkRoberts
    I'm not an electronic type person but here are some thoughts...
    Dry joint somewhere between the NI and the unit (try a different cable?)
    RFI (try adding those little black jobs at ?both ends?)
    Nasty power supply (try adding a UPS?)
    Bad UART in the NI (try a different NI or a different port?)
    Bad UART in the unit (try a different Plasma?)
  • DHawthorne
    DHawthorne Junior Member
    I've done quite a few Fujitsu's and have never seen that. I would suspect a bad port on the TV or a flaky cable.
