Ni 2000 Memory
ryanwwryanww Junior Member
I have an NI-2000 with a piece of code in it that seems to be taking a lot of resources away from the processor or something. I have quite a few devices on it that are polling a lot for updates.
I am looking to use a couple g3 web panels served off of it, but the browser is really slow. Is there a way to re-adjust the memory to help speed that up maybe? It is running the latest duet firmware. I know I can adjust the duet memory, but I don't know if that would affect it.
Ryan
    Check out tech notes 790 and 766. The magic number seems to be 12M. Tech note 766 states trial and error as the way to determine the amount of DUET memory needed, not very scientific. :( One would think there should be a better way.
  • viningvining X Member
    I usually count my fingers and toes and then divide by two. So far I keep getting a result of 10 and with any luck that number won't change.
  • ryanwwryanww Junior Member
    Cool.. Thanks, I should have checked that first.. didn't even think about it. I will try it when I am back on site.
    Ryan
    If you take Nyquil, stay clear of table saws.
    Yeah, but you don't need Nyquil. I lopped off the corner of my thumb with a table saw, taped the piece back on and went back to work. Then smashed the same thumb with a hammer twice before giving up for the day.
  • vining wrote:
    ...and ended your modeling career
  • jazzwyldjazzwyld Registered User
    Taking a Hint
    Well maybe the hammer percussion's were meant to help secure the thumb after the dismemberment. There are many times I use sudden applications of pressure to secure pieces of flesh to my body.
    I'm not going to say a thing.
    The most it will let me set it to is 8mb.. why is that? Is the CF card just too small? It is a ni2000 and I believe a 32 meg card.
    Ryan
  • GeoGeo Junior Member
    Not 100% sure but I think the NI2000 only lets you go up to 8M. I have a 4100 that will allow anything from 2M to 36M, but 10 to 12 seems to do the trick every time. For smaller projects, I've had good luck with anything above 3M.
    Well I guess I will put it at 8 and see how it works.. It did seem to speed up the web interface a bit..
    Ryan
