Lib file not found
I have problem with compiling project. NLS tells me about ERROR:
ERROR: (0): L20219: File not found: [devicesdkrt.jar] version [1.8.0]
it is found in boudle folder of Libs, when i'm removing it compiler says:
ERROR: (0): L20219: File not found: [devicesdkrt.jar].
Do i need this file wit right version or this can be solved by another way?
Kinda the point of having these forums, donchaknow...
- Chip
The file in my lib folder had a different name than I was specifying. It took a little while to figure out, but I finally stumbled across it.
I am not sure if that is what happened here, but it may save someone else.
I've post about problem before careful search that's why i'm sorry. And looks like not in the right place...
Here it was settled:
http://www.amxforums.com/showthread.php?t=1956
