Polycom VSX UI
I'm working on a system based around only a VSX7000e but the client wishes to make voice, ISDN and IP calls all on the vsx. Normally we install a seperate audio codec in combination with the vsx for heavy voice use, but in this instance we're not...
Everything is working fine using my normal vsx module, but I wondered if anyone had any tips for simplify the UI for the vsx - the amx modules and TP files aren't overly simple, so just wondered how others had worked this?
