MVP-8400i Telnet Security
Sensiva
Sensiva Junior Member
Good day to you...
I didn't find any document mentioning Telnet login security for MVPs... am I right?
  • vincen
    vincen Junior Member
    Sensiva wrote:
    Good day to you...
    Well you can't setup on MVP same setup system as on master, but you can allow/disallow telnet server in MVP (go in Setup Pages -> Protected and then you have a button to allow/disallow telnet access to MVP :)
    Vinc
  • Sensiva
    I Use Telnet to go to setup
    When answering supporting calls, or even fixing something without going to the clients place, I use Telnet to go to the setup page, so turning it OFF will get me stuck.... Won't be able to Re-enable it again.
  • Marc Scheibein
    Marc Scheibein Junior Member
    Telnet is also working over USB!!
    For this, the panel is not required to be set to USB connection mode, but you need to have installed the AMX USBLan Driver on your PC. The USBLanLink tool establishes a virtual network card on your PC with IP address 10.0.0.1 by default. The panel is running on IP 10.0.0.2.
    So just connect a Modero panel by USB with your PC, launch a telnet session to 10.0.0.2 and have fun :-)
  • jweather
    jweather Junior Member
    You forgot to mention the USB over TCP/IP adapter you use to do this over the Internet, as Sensiva was hoping to be able to do...
    If you just need to trigger the setup page, why not do it from the master? Then you just need remote access to the master, and can use Control A Device to send the command to the panel, or rig up something fancier with a TCP/IP port listening on the master for debugging access. Perhaps I'm missing something here...
    Jeremy
  • annuello
    annuello Junior Member
    From time to time I find that my MVPs stop communicating with their masters. If the master can't contact the TP, there is no way to send a SETUP command to the TP. Some nice telnet features (that don't disturb active users) are:
    GET CONNECTION to verify that the panel is pointed to the correct master
    SHOW CONNECTION LOG to see network reliability
    GET IP when your TP has a DNS entry rather than static IP
    I would like to see improved telnet security across the whole G4 range. (I use MVPs and CV7s.) At this point in time, anyone can telnet into my panels and reboot them, change IP settings, etc. A simple username/password (or even just a PIN) would be suitable.
    Roger McLean
    Swinburne University
  • Sensiva
    Thanks for this addition
    Thank you for this great addition, Will be helpful in installation procedures, but as JWeather mentioned..... I am interested in Telneting over WAN.... Anyway, We will just keep waiting for this feature, I hope it come up soon.
