HAI OmniProII Protocol
I was looking around and found some mention about having to write a module for the HAI Omni Pro II.
I am using the latest version of the duet module, but i can't seem to find where you can select direct thermostats to control. In the module there is an index and based on which index number you are on, it will display the thermostats in the variable text fields ( 9 - 14 ), i want to be able to directly select the thermostat based on which room you are in.
Anyone have any luck with the protocol to get it to correctly select a thermostat? I have the protocol but can't seem to get the passthru command to work correctly keeps giving me a java error.
Any help would be great thanks
  • banobano Senior Member
    Try the non-duet standard netlinx module hai_omniproii_v2.5.
    Good Luck!
