AMX NI-3100 IP Comm issue?
in AMX Hardware
Just got back from a Job Site where my NI-3100 was responding painfully slow. Connection Dropped constantly from Telnet and Studio, But the Touchpanel (A MVP-8400) ALways stayed Green.
AMX is replacing it, but the loaner I put in was responding similarly (Although not qute as bad)
I use Zyxel Gigabit Switches.(G-105a inthis case)
So I forced the Master to 100 Half and everything started communicating the way it should.
Is this a problem with the Auto detection on the NI's? Is it getting completely confused because its connected to a Gigabit switch?
Has anyone else noticed this kind of behavior?
I've had the same problems with IP communications. setting it to 10 half seems to always clear up any problems. There's really no problem running them that slow. They do just fine.
Its weird.. SOmetimes(Most of the time actually) I leave it default out of the box and it runs fine... But then some just need to be forced toa specific speed.... Dunno if its the switches I'm using or the NI's
