Parsing Data from a Webpage
2»
    Actually, http://inteliplex.com/wx and http://inteliplex.com/wx/ are two different URLs. You're requesting the former, it's redirecting you to the latter. Send GET /wx/ HTTP/1.1 and all should be well.
    I believe it does the redirect so that if you have relative links on the /wx/index.html page (say to test.html), they redirect consistently to /wx/test.html in all cases rather than to /test.html if the user browsed to http://inteliplex.com/wx -- make sense?
    Jeremy
    jweather wrote: »
    Jeremy
    Interesting... thanks for pointing that out.
    When I send this (ZIP_CODE is 65065)
    SEND_STRING 0:nLOCAL_PORT+1:0,"'GET /weather/map/',ZIP_CODE,' HTTP/1.1',13,10,
    	'Host: www.weather.com',13,10,
    	'User-Agent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9) Gecko/2008052906 Firefox/3.0',13,10,
    	'Accept: */*',13,10,
    	'Accept-Language: en-us,en;q=0.5',13,10,13,10"
    I get this . . .
    HTTP/1.1 307 Temporary Redirect
    Date: Fri, 20 Jun 2008 20:37:58 GMT
    Server: Apache
    Set-Cookie: partner=www; domain=(null); path=/; Version="1";
    Set-Cookie: partner_url=(null); domain=(null); path=/; Version="1";
    Location: [url]http://www.weather.com/weather/map/65065[/url]
    Content-Length: 443
    Keep-Alive: timeout=3, max=1
    Connection: Keep-Alive
    Content-Type: text/html; charset=iso-8859-1
    <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
    <html><head>
    <title>307 Temporary Redirect</title>
    </head><body>
    <h1>Temporary Redirect</h1>
    <p>The document has moved <a href="http://www.weather.com/weather/map/65065">here</a>.</p>
    <p>Additionally, a 307 Temporary Redirect
    error was encountered while trying to use an ErrorDocument to handle the request.</p>
    <hr>
    <address>Apache Server at [url]www.weather.com[/url] Port 80</address>
    </body></html>
    Anyone? Please? :D
  • slip couganslip cougan Junior Member
    i!-EquipmentMonitorOut.axi
    Where can I find this file?
    gary
  • viningvining X Member
    Try this URL:
    http://www.weather.com/weather/tenday/USMO0665?cm_ven=LWO&cm_pla=city_page&cm_ite=10-day&site=city_page&cm_cat=rss&locid=USMO0665&par=LWO_rss
    Thanks, but I don't need the forecast, I'm trying to get the "local" radar for a specified zip code, and trying to scrape the image from returned html. :(
    Gary,
    Log into AMX.com, then go to Tech Center -> Application Files -> integration! solutions and it should be there.
    OK, try this site.
    http://www.srh.noaa.gov/ridge/lite/
    Click on a radar image type and then select an area from the list. Here's some snipets of code to help you figure out what your looking at.
    char Rad_Image_Type [9][3]=
         'N0R', // Base Reflectivity
         'N0S', // Storm Relative Motion
         'N0V', // Base Velocity
         'N1P', // One-Hour Precipitation
         'NCR', // Composite Reflectivity
         'NTP', // Storm Total Precipitation
         'N0Z', //Base Reflectivity //Long Range image (view out to 248 nmi)
         'NET', //
         'NVL'  //
     //MISSOURI
         RadState.Missouri[1].Area = 'Kansas City' ;
         RadState.Missouri[2].Area = 'Springfield' ;
         RadState.Missouri[3].Area = 'St. Louis' ;
         RadState.Missouri[1].Code = 'eax' ;
         RadState.Missouri[2].Code = 'sgf' ;
         RadState.Missouri[3].Code = 'lsx' ;
    I never quite finished this module and I intended on making every radar site in the US available. I did finish the Satellite portion, I think?
    Thanks . . . I think I'm being too picky. LOL!
    I can go ahead and scrape out the image I need if I can get to the source I see in my browser, I just think there's too much redirection going on. I want to stick with Weather.com since I think they're the most familiar and legible radar maps for the common client.
    Thanks though!!!
    Quick update: I was finally able to find it. I had to include the "encoding" attribute, and I was then able to read the entire page and get the data I needed.
    What a PIA! Glad ya' found it though.
    jjames wrote: »
    Chip Moody wrote: »
    Thanks . . . actually, let me show you what I had to send:
    SEND_STRING 0:nLOCAL_PORT+1:0,"'GET /forecast/',ZIP_CODE,'.html HTTP/1.1',13,10,
    			'Host: weather.yahoo.com',13,10,
    			'User-Agent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1)',13,10,
    			'Accept-Encoding: deflate;q=0',13,10,
    			'TE: deflate;q=0',13,10,
    			'expires: #now()#',13,10,
    			'Keep-Alive: 300',13,10,
    			'Cache-Control: no-cache, no-store, must-revalidate',13,10,
    			'charset: utf-8',13,10,13,10"
    It wasn't the "encoding" (my bad), it was the "charset". After a while Googl'ing, I came across this suggestion and it sure enough worked. It was a PITA . . . I've got it all working now, except I cannot load the Alaskan Doppler radar becase, well . . . there isn't one. [EDIT: There isn't a 600 mile radar, only the 2100 - though that might be good enough.]
    So, now I need to adjust it . . . ugh. Oh well, the stuff you gotta go through to do something "cool" and probably won't be used much. ;)
