Aethra X5 IR Code doesnt work
HIya...
I am try to control Aethra X5
I have the remote and an IRIS but there are two codes that I cannot learn.
They are the OK button and the (*.) button. Any solution or suggestion?
Thx...
Cheers
Thx...
Cheers
HTH
Thx, Jim.
I try before, but still have the same problem on there. Is there anyother method or solution ?
If you can get your hands on a Pronto remote and if the Pronto can indeed learn the commands correctly, you can then use ProntoEdit to get a copy of the hex codes and then paste them into your IRL with IREdit. Same holds true with an RTI remote and RTIs software. I?m not sure what other learning remotes let you view the hex codes, those are the two that I?m aware of.
HTH
Some time back I wrote a $res^ron IR file format to Pronto converter. The output can be directly imported into IREdit.
http://www.remotecentral.com/files/ind-179.htm
The updated version is here:
http://www.indyelectronics.com/ir2pronto.zip
Hiya..
Finally I got the IR code rom Aethra..and it work...
thx all of U...
Eric
I have the same issue
