G4 Panel Preview Feature Request
This is a request for G4 Panel Preview to include a feature that displays the channel code when a button is pushed similar to how the preview works for TPDesign 3.
Joe
  • DHawthorne
    DHawthorne Junior Member
    And while we're at it, how about the ability to turn off the audible on button presses? :)
  • Rob Whapham
    Rob Whapham AMX Engineering
    The button press sounds can, in fact, be turned off; and in the same way you would do it on a regular panel. Simply choose View->Goto Setup Page (or use any on-screen buttons you might have that flip to the Setup Pages). From there, you can turn on and off the button hit and/or miss sounds from the 'Default Panel Sounds' section.
