MAX UI module 1.65
in MAX by AMX
This UI is working only with one TP from I undestand?
What if there are 2 or more TPs in the same system for this module?
Not to mention that in the house I am working now you can go from every TP to every room...
Did someone ever tried it with Multi TP's configuration?
From what I saw in the code it a huge change...
Maybe the solution is to run several instances of the module on the same system? (UI only)
I am not sure this is good for me...
I need to be able to enter room X from TP1 and TP2.
I can't connect TP1 to a specific module, cause maybeI want to enter and controll this module from TP2...
get_last mechanizm solved me this issue , I don't think I can solve it this way without changing the code...
Maybe the way to solve it by Zone selecting?
I saw that in the UI that coming with the Duet module the main screen gives Zone selection.
This way I can set the zone of the selected room without care from what TP.
You can also consider reworking the UI so that the zone selector is easier to find for the client instead of having multiple button presses to get him to selecting the zone, then back to selecting the source material.
--John
That is sound good
I will set the zone (in code)according to the room the user wants to control, but the TP will keep on working with its individual module no matter what (module for every TP)
Or I have to do it screen by sceen?
Maybe that is a silly Question, but the comm module will be ony one instance, right?
Correct - one comm, multiple UI. The virtual for the comm is passed to all the UI modules as a parameter and can be the same for all of them.
Thanks Dave.
I integrated it to all my systems and made a nice message base "SET_ZONE" so I can control any room from any TP.
They did a greate job on this module ( I saw the bugs thread)
Whats left is to change the look of the UI to be look like the rest of the house.
