TPDesign4.2.3.1 bug
Joe
Joe Junior Member
I am running the latest version of TPDesign4 (build 353) and a funny thing occurs when I try to remove a bitmap from a button. When I select 'None", I get the error 'The value entered is not valid'. So to remove the bitmap, I have to delete the button and create a new one. Anyone else run into this?
  • Rob Whapham
    Rob Whapham AMX Engineering
    I haven't had any success attempting to reproduce with this TPDesign4 2.3.1 Build 253. Perhaps you could ZIP and attach the TP4 file that is causing this for you and give instructions how to recreate the problem. Thanks.
