Unable to retrieve device list from the master
pauljloz
in AMX Hardware
Anyone encountered this problem?
After adding a AXB-TMC (v2.11) to the AXLINK bus, when using Open Access 1.12 (Build 4) I encounter the message:
"Unable to retrieve device list from the master. Please confirm (connection active) and (master version is 3.90 or higher)."
Removing the AXB-TMC (v2.11) from the AXLINK bus allows normal operation of Open Access.
Other devices are an AXCENT3 Pro (v4.90) and a PC4 (actually a CPI16) (v2.10).
Netlinx Studio lists all items correctly and IREdit work fine uploading to the TMC.
Is this related to the Axcent3 firmware version?
Paul
Paul
The only time I have seen this particular error was when there was something wrong with the AxLink buss - shorted pairs on the cable, a bad device, or just plain mis-wired.
This error can be replicated using a known good cable and with only the TMC on the AXLINK bus.
The device otherwise appears to function OK.
Curious -
I'd venture to say the TMC is bad. Have you tried it on another master?
