hitachi plasma tv 42pd9800 protocol
bruce
Hi
Does anybody got the rs232 control protocol for the hitachi plasma 42PD9800 model?
Thanks.
Bruce
Thanks.
Bruce
i think this will help u!!
remember u need to get in the setup inorder to ena rs232 on hitachi:
Business Products Consumer Products
42PMA500E 32PD5200 / 5300
42PMA500EZ 37PD5200 / 5300
CMP4211E 42PD5000 / 5100 / 5200 / 5300
CMP4212E
CMP4213E
CMP4214E
This information should be read in conjunction with the following documents:-
1) Protocol Specification Document
2) Protocol Technical Info
3) Product User Manual
Ref:- Cable Wiring Info
The cable should have a 9 pin D-Sub (female) connector at each end.
The max cable length of RS232c is 15m.
The pins that should be wired are as follows:-
All the remaining pins have no connections..
Ref:- Command Structure.
The following list is an example of the command structure required. For a full listing of the commands available to the s/w developer, please refer to the Protocol Specification Document.
Commands (Hex, no spaces required) Comments
05 Enter Terminal mode
04 Exit from Terminal mode
02 36 45 30 30 30 30 30 30 30 30 30 31 03 Power On (from standby mode)
02 36 45 30 30 30 30 30 30 30 30 30 30 03 Power off (go to standby mode)
02 36 46 30 30 30 30 30 30 30 30 30 30 03 Select RGB1 (DVI) i/p
02 36 46 30 30 30 30 30 30 30 30 30 31 03 Select RGB2 (D Sub) i/p
02 36 46 30 30 30 30 30 30 30 30 30 32 03 Select AV1 (Composite Video / Component) i/p
02 36 46 30 30 30 30 30 30 30 30 30 33 03 Select AV2 (Composite Video / Component) i/p
02 36 46 30 30 30 30 30 30 30 30 30 34 03 Select AV3 (SVHS) i/p
02 36 46 30 30 30 30 30 30 30 30 30 35 03 Select AV4 (SCART) i/p
02 35 45 30 30 30 30 30 30 30 30 30 30 03 Orbiter Mode - off
02 35 45 30 30 30 30 30 30 30 30 30 31 03 Orbiter Mode - on (set to 5 mins)
02 35 45 30 30 30 30 30 34 30 30 30 30 03 Inverse Image - off
02 35 45 30 30 30 30 30 34 30 30 30 31 03 Inverse Image - on
02 35 45 30 30 30 30 30 35 30 30 30 30 03 Screen wipe - off (white)
02 35 45 30 30 30 30 30 35 30 30 30 31 03 Screen wipe - on (white)
02 36 33 30 30 30 30 30 30 30 30 30 30 03 RGB auto adjust.
02 37 30 30 30 30 30 30 30 30 30 30 30 03 Display mode ? off (remove OSD i/p freq)
02 37 30 30 30 30 30 30 30 30 30 30 31 03 Display mode ? on (show OSD i/p freq)
The following are brief examples showing the command structure.
Example 1 :- Power on plasma display
02 36 45 30 30 30 30 30 30 30 30 30 31 03 Power On (from stby mode)
Example 2 :- Change i/p to RGB2.
Example 3 :- Change i/p to SVHS.
