Levels first time
adysadys Junior Member
Hi all
I read a lot and made my first levels use.
I just wanted get ok on my code to see that I am not doing ugly things that will not work :)
I have a music modlue that controls volume
I have a virtual device vdvMusicLevels = 33005:1:5 inside the music module (as parameter)
then every time I get a volume change I send level update to the vdvMusicLevels:
send_level vdvMusicLevels, ELECTRIC_JACUZZI_OUTPUT, volume
( is that enough or I need to declare the levels before sending them? )
then in my listeners side (inside other module) , I create a level in start section:
create_level vdvMusicLevels, ELECTRIC_JACUZZI_OUTPUT, m_volumeToUpdate
is this is the only thing I need to do to get m_volumeToUpdate to be updated?
thanks a lot
Ady
update:
I made some test code to check it, and its not working....
I see with the debugger that I send the level, but my "m_volumeToUpdate" is not updated
other string message are working good between those 2 module.
m_volumeToUpdate is declared as integer, and the value that sent to the level is also integer.
I made m_volumeToUpdate to be VOLATILE, still not working...
I am stuck, thanks for any help
update 2:
This solved the problem
SET_VIRTUAL_LEVEL_COUNT(vdvMusicLevels, 24)
    Yeah, you have to do that when a virtual device has more than 8 levels defined. I was scratching my head, because your examples were fine, but then, I didn't know the value of the actual level because you used a constant alias.
