Address book Module/Code
cmatkincmatkin Senior Member
Hi all,
I was wondering if any one would have or know of an "Address book" module/code that I could get my hands on.
I'm after function like add, remove, edit, sort and find.
Regards
Craig
  • SensivaSensiva Junior Member
    Module/Code
    Hi.... You should say address book for what?? which device, model, manufacturer..
    Go to InConcert and .. search, if you don't have an account, sign up for one.
    Addressbook Functions
    This should give you an idea how to do it, just provided the helper functions.
    DEFINE_CONSTANT
    MAX_STRUCT_ITEM_LENGTH = 50;
    MAX_ADDRESSBOOK_ENTRIES = 100;
    DEFINE_TYPE
    STRUCTURE _AddressBookEntry
    	CHAR cFirstName[MAX_STRUCT_ITEM_LENGTH];
    	CHAR cLastName[MAX_STRUCT_ITEM_LENGTH];
    	CHAR cAddress1[MAX_STRUCT_ITEM_LENGTH];
    	CHAR cAddress2[MAX_STRUCT_ITEM_LENGTH];
    	CHAR cCity[MAX_STRUCT_ITEM_LENGTH];
    	CHAR cState[MAX_STRUCT_ITEM_LENGTH];
    	CHAR cZip[MAX_STRUCT_ITEM_LENGTH];
    	CHAR cPhone[MAX_STRUCT_ITEM_LENGTH];
    	CHAR cFax[MAX_STRUCT_ITEM_LENGTH];
    	CHAR cEmail[MAX_STRUCT_ITEM_LENGTH];
    DEFINE_VARIABLE
    non_volatile _AddressBookEntry uMyAddressbook[MAX_ADDRESSBOOK_ENTRIES];
    VOLATILE _AddressBookEntry uUserEntryItem;
    DEFINE_FUNCTION INTEGER CompareAddressBookItems (_AddressBookEntry uItem1, _AddressBookEntry uItem2)
    	IF ( (uItem1.cAddress1 	== uItem2.cAddress1) 	&&
                          (uItem1.cAddress2 	== uItem2.cAddress2) 	&&
    	      (uItem1.cCity 		== uItem2.cCity) 		&&
    	      (uItem1.cEmail 		== uItem2.cEmail) 		&&
    	      (uItem1.cFax 		== uItem2.cFax) 		&&
    	      (uItem1.cFirstName              == uItem2.cFirstName)              &&
    	      (uItem1.cLastName 	== uItem2.cLastName) 	&&
    	      (uItem1.cPhone 		== uItem2.cPhone) 		&&
    	      (uItem1.cState 		== uItem2.cState) 		&&
    	      (uItem1.cZip 		== uItem2.cZip) )
    		RETURN TRUE;
    	ELSE
    		RETURN FALSE;
    DEFINE_FUNCTION INTEGER FindAddressBookEntry (_AddressBookEntry uItem)
    	STACK_VAR INTEGER nLoop;
    	FOR (nLoop = 1; nLoop <= MAX_LENGTH_ARRAY(uMyAddressbook); nLoop++)
    		IF (CompareAddressBookItems(uItem, uMyAddressbook[nLoop]) == TRUE)
    			RETURN nLoop;
    	RETURN 0;
    DEFINE_FUNCTION INTEGER AddAddressBookEntry (_AddressBookEntry uItem)
    	STACK_VAR INTEGER nLoop, nLocation;
    	STACK_VAR _AddressBookEntry uAddressbookNull;
    	// SEE IF ALREADY IN ADDRESSBOOK
    	nLocation = FindAddressBookEntry(uItem);
    	IF (nLocation == 0)
    		// GET NEXT AVAILABLE SPOT
    		nLocation = FindAddressBookEntry(uAddressbookNull);
    		IF (nLocation > 0)
    			uMyAddressbook[nLocation] = uItem;
    			SortAddressbook(uMyAddressbook);
    			RETURN nLocation;
    	RETURN 0;
    DEFINE_FUNCTION INTEGER DeleteAddressBookEntry (_AddressBookEntry uItem)
    	IF (nLocation > 0)
    		uMyAddressbook[nLocation] = uAddressbookNull;
    		RETURN nLocation;
    	RETURN 0;
    DEFINE_FUNCTION INTEGER UpdateAddressBookEntry (_AddressBookEntry uOldItem,_AddressBookEntry uUpdateItem)
    	nLocation = FindAddressBookEntry(uOldItem);
    	IF (nLocation > 0)
    		uMyAddressbook[nLocation] = uUpdateItem;
    		RETURN nLocation;
    	RETURN 0;
    DEFINE_FUNCTION SortAddressbook(_AddressBookEntry uAddressbook[])
    	STACK_VAR INTEGER nLoopA, nLoopB;
    	STACK_VAR _AddressBookEntry uHold;
    	FOR (nLoopA = 1; nLoopA <= MAX_LENGTH_ARRAY(uAddressbook); nLoopA++)
    		FOR (nLoopB = nLoopA + 1; nLoopB <= MAX_LENGTH_ARRAY(uAddressbook); nLoopB++)
    			IF (CompareAddressBookItems(uAddressbook[nLoopB], uAddressbookNull) == FALSE)
    				IF (uAddressbook[nLoopA].cLastName >= uAddressbook[nLoopB].cLastName && uAddressbook[nLoopA].cFirstName > uAddressbook[nLoopB].cFirstName)
    					uHold = uAddressbook[nLoopB];
    					uAddressbook[nLoopB] = uAddressbook[nLoopA];
    					uAddressbook[nLoopA] = uHold;
    DEFINE_START
    uUserEntryItem.cFirstName = 'Judy';
    uUserEntryItem.cLastName = 'Jetson';
    AddAddressBookEntry (uUserEntryItem);
    uUserEntryItem.cFirstName = 'Astro';
    uUserEntryItem.cFirstName = 'George';
    uUserEntryItem.cFirstName = 'Jane';
    uUserEntryItem.cFirstName = 'Rosy';
    uUserEntryItem.cLastName = 'The Maid';
    uUserEntryItem.cFirstName = 'Elroy';
