Listbox on MIO DMS Pinnacle - get a button event from it?
I can't figure out how to get a button push in a dynamic listbox on a DMS to return any kind of button_event back to the controller. I'm getting the dynamic list loaded into the panel OK, and I'm specifying a "Channel" field in that list, but button pushes don't show up in the NetLinx device notifications.
When I enable Netlinx Device Notifications, I don't see any kind of button push from the dvTP_AB. How do I get it to send that Channel number (3rd column in the list definition) to the controller?
Code snippets below...
DEFINE_DEVICE dvTP_AB = 10003:1:0 DEFINE_CALL 'tpsetup' () { SEND_COMMAND dvTP_AB,"'^LDD-1'" SEND_COMMAND dvTP_AB,"'^LDN-1,1,3,eventselector'" SEND_COMMAND dvTP_AB,"'^LDT-1,1,0,0,3'" SEND_COMMAND dvTP_AB,"'^LDA-1,0,1,Setup 1,21'" SEND_COMMAND dvTP_AB,"'^LDA-1,0,2,Setup 2,22'" SEND_COMMAND dvTP_AB,"'^LDA-1,0,3,Setup 4,24'" SEND_COMMAND dvTP_AB,"'^LDA-1,0,4,Setup 7,27'" SEND_COMMAND dvTP_AB,"'^LVC-1,2,1,3'" SEND_COMMAND dvTP_AB,"'^LVU-1'" } DEFINE_EVENT data_event[dvTP_AB] { online: { send_command data.device,"'PAGE-Selection'" call tpsetup () } string: { send_string debug,"'Panel AB Sez: "',data.text" } button_event[dvTP_AB,21] button_event[dvTP_AB,22] button_event[dvTP_AB,23] button_event[dvTP_AB,24] button_event[dvTP_AB,25] button_event[dvTP_AB,26] button_event[dvTP_AB,27] button_event[dvTP_AB,28] button_event[dvTP_AB,29] { send_string debug,"'AB Panel Button Event: "',itoa(button.input.channel)" }
