Security System Interfacing
Greetings,
I have a customer building a new home and I need to recommend a security system that will work well with the AMX system that I am providing.
I have worked with a GE Concord, but was a buggy experience.
I have also worked with the Ademco Vista, but it had no way of doing a panic alarm from the AMX UI.
Any suggestions? Being able to monitor the alarm status and to be able to initiate a panic from AMX would be primary concerns.
Thaks.
Thaks.
Well there is no specific panic button on the UI. There could be a numerical sequence of some sort to initiate panic, but I am currently unaware of it.
I have integrated with the Napco Gemini many times. AMX has a module, but it is firmware dependant. You will usually need to work with someone within the security company to make sure you have the right firmware. While it is possible to arm, disarm, etc. we make it a policy to only monitor what the security system is doing due to liability. A common practice for us is to send an eMail or text messages if the alarm is disarmed or set off. One minor problem with the napco gemini is that it dosnt prioritize messages, so there can be a bit off a delay between the event and the report.
http://www.elkproducts.com/
1. The protocol is not as easy as Elk?s protocol.
2. You need to send a ping every 2 minutes or you get logged out.
3. You can't just view one zone change at a time; you have to query the complete string of all zones. We use zone motion feedback for late night lighting.
4. Easy PC interface programming.
5. You can write ASCII strings and send them to the AMX for triggering.
6. If you use the HAI thermostats, the temperature feedback is not super accurate. With Elk you can use different thermostats.
I should get a free one after this hard sell.
