LCD Aquos serial command problem
Hello Guys,
I have some problems with the serial commands. When I sent the power off it's ok (tx and rx led blinking), but when I sent the power on command always rx led blink.
Ceers
Ceers
Tanks
I called up Sharp tech support and the answer I received was they couldn't enable serial power on function and keep the Green Energy Saver certification.
I pointed out several other TV manufactures managed to do it and I got no response other then the suggestion to use IR to turn the unit on. (What?s the point of 232 then?)
