Netlinx Diagnostics
glr-fti
I can use diagnostics within Studio no problem but I when I launch Netlinx Diagnostics 1.14 it fails to connect using the same settings as Studio. Anyone else have that problem?
Thanks.
Thanks.
Not sure if NetLinx Diagnostic Tool is working with the current masters (NI-x100) in general.
One of the masters I am trying to get to is a NIx100 but the other is a NIx000 and I have the same problem. I have gotten to the NIx000 with the tool in the past.
Did you check about login/pass if you have activated security on NetLinx master ?
Also don't forget you can't be connected in debug with two different software in same time as master is supposed to accept debug system from only one system at a time
Vince -
It might be a firewall setting on your PC; Studio is permitted to go out, but Diagnostics isn't.
The problem was with security activated on the master.
Thanks for the ideas.
