Multi state buttons
adys
adys Junior Member
Hi all
I am using multi state general buttons to represent more than 2 states. I must do it with states cause I am not controling the text - its constant text on the bitmap.
in general buttons I am switching the states using the ON[tp, button_channel] / OFF[tp, button_channel]
What is the way to do it in a multi state buttons?
I found this post - is this is the only way to do it?
http://www.amxforums.com/showthread.php?t=1224&highlight=multi+state
Ady.
  • yuri
    yuri Junior Member
    you can use on and off on a multistate button. It will then show the first state followed by the next, etc etc until it hits the last state.
    If you want to select a specific state on a multistate button you need the ^ANI command :)
  • jjames
    You could also turn it into a multi-state bargraph and send it a level. And it would be as simple as "SEND_LEVEL dvTP1, 1, nSTATE" where nSTATE would be the step you want it in.
    I just woke up, I may be VERY wrong . . . but it sounds good at least!
  • vining
    vining X Member
    Sounds good to me and I've been up for hours!
  • DHawthorne
    DHawthorne Junior Member
    That's how I do it. I simply find it far easier and more elegant to update the state with a send_level. I can't think of the last time I used a multistate button outside of a simple animation to go from ON to OFF. ANy time I want to track intermediate states, I make it a bargraph.
  • adys
    adys Junior Member
    thanks guys, I done some code with ^ANI but the next button I will check with LEVELS
