Dynamic Image Refreshing
Greetings All,
I have some panels on which I am using dynamic images from a web server. Is there a way to have them refresh from code? I have them set in TPD4 for a refresh every few minutes. I would like them to refresh as soon as the page that contains the buttons is flipped to. Thanks!
  • vining
    vining X Member
     "'^RFR-<resource name>'"
          Force a refresh for a given resource.
          Syntax:
                SEND_COMMAND <DEV>,"'^RFR-<resource name>'"
          Variables:
                resource name = 1 - 50 ASCII characters.
          Example:
                SEND_COMMAND Panel,"'^RFR-Sports_Image'"
                Forces a s refresh on 'Sports_Image'.
    In dynamic images you can set the refresh rate to zero and then use this command to refresh when ever you want.
