Big Oops!
I just thought I'd share with everyone a mistake I made that sent me on a goose chase on trying to find the culprit. In my DEFINE_PROGRAM section, I had a function being called that returned a value. Here's a snippet:
After about 10 minutes looking at it, it finally clicked! So to fix the problem I created a STACK_VAR in the begining of the function and used that for the FOR loop. A stupid mistake on my part, but I just thought I'd share my embarassing moment in programming in hopes that others will at least learn from my mistake. Talk about a BIG OOPS!
FOR (nLOOP=1;nLOOP<=LENGTH_ARRAY(dv_TP);nLOOP++) { // Camera select feedback FOR(nLOOP1 = 1;nLOOP1<=LENGTH_ARRAY(nCAMERA_BTNS);nLOOP1++) [dv_TP[nLOOP],nCAMERA_BTNS[nLOOP1]] = (nCAM_SEL[nLOOP][fnGET_ROOM(nLOOP)] = nLOOP1) }Well, the panels can control multiple rooms so I need to know which room it was in. I could have used a simple room select variable, to keep track, but I was trying something new. Anyway... here's the function code:
DEFINE_FUNCTION INTEGER fnGET_ROOM (* Get which room is being controlled */ (INTEGER nPANEL) { FOR(nLOOP = 1; nLOOP <= 5; nLOOP++) { IF(nPNL_AV[nPANEL] == nAV_ZONE_MAP[nPANEL][nLOOP]) { RETURN nLOOP; BREAK; } } }Can anyone spot the culprit right away? It took me a little bit to actually find it. I'm passing a variable into the function (nLOOP), and the variabled used for the FOR loop is ... nLOOP. I didn't even think about the variable getting used in multiple places at the "same" time. Well, here's the thing: it didn't cause any runtime errors, or anything like that. I was stuck! I couldn't even "pause" the program in debug. I figured it had to be something in the DEFINE_PROGRAM, so I started commenting things out and looking to see what could have messed up my program.
My local variables all have "My" in their name and function call arguments all have "Arg" in their name. Globals have neither.
