NuVo Zero
So we go the NuVo XM/AM/FM/WB tuner. Very slick piece, I like it. I've run into one problem though. I can't see to get the "ZERO" command working on the XM piece while direct tuning. This is the command I'm sending, followed by a carriage return:
Any ideas why it isn't working?
*T'B'ZERO
Then the cTUNER_B is inserted where the 'B' would go. So it's essentialy
OMG!!! Are you ready for this crap? To send a Zero to the XM module, you need to send 'TEN' and not 'ZERO'. However, for the AM/FM/WB module, 'ZERO' works fine. Grrr - it's a shame they didn't document this. I happened to stumble across this by accident, trying to figure what else "zero" could equate to.
So, BEWARE!!! Use *T'x'TEN instead of *T'x'ZERO for a the number zero on the XM piece of the NuVo tuner (where x is either "A" or "B").
What a waste of time!
